Thin PET film, sheet gets the polish
Published: December 31st, 2005
To alleviate these problems, this equipment producer has introduced the JuBo polishing roll (Justierbare = adjustable; Bombage = crowning), the first roll in a 3-roll stack. The technology is suitable for wide roll stack extrusion lines producing film in thickness from 1200-1000 µm. Films down to 100 µm are possible by slight modification of the unit.
An oil-filled cavity is placed under the cooling spirals, its shape calculated by finite element method. During operation, the cavity reaches the temperature level needed for the polishing roll's cooling water. Depending on the temperature, pressure up to 300 bar can be reached within the oil cavity. This is said to create symmetrical deformation of the roll's outer shell, resulting in a crowing up to 300 µm in the centerline. The unit is intended for credit card overlay film, graphic arts sheet, as well as form-fill-seal and thermoforming web. Brückner Formtec GmbH, Siegsdorf, Germany; +49 8662 63268; www.brueckner.com
