Tension, tearing and more tested up to 1 kN
Published: March 23rd, 2011
The LS1 high performance single column materials testing machine debuted by Lloyd Instruments (Bognor Regis, UK) can test tension, compression, tearing, peeling, friction and flexural properties of plastic samples and finished products with loads of up to 1 kN applicable.
Featuring a full suite of control and test software functionality with seamless data transfer, enhanced slow movement capability with linear response, a powerful security and audit trail function, and dedicated sample holding grips and fixtures, a load accuracy of 0.5% down to 1% of load cell value provides high accuracy measurement.
Supplied with a remote hand-held controller or an optional LCD control console for stand-alone operation, the LS1 test machine is also available with full computer control using a new version of Lloyd InstrumentsPlus test and control software. An extensive range of load cells and grips, together with the ability to accommodate up to two extensometers simultaneously allow the new LS1 test machine to provide a simplified testing platform that can be used throughout the manufacturing cycle, right from the evaluation of raw product to the testing of finished product and all stages in between.-immeditorial@ubm.com
