Water and air cooling innovations to debut at K
Published: July 21st, 2010
Two advances that will reportedly have a major impact on future cooling systems for plastics will be unveiled at the K Show by Eurochiller. Energy-saving inverter controlled compressors are employed in the latest water cooling system, while a free-cooling function will be introduced for air cooling.
| Outside air used for bubble cooling in extrusion. |
For water cooling, Eurochiller's NAX Inverter, available in three models with cooling capacity included between 90-400 kW, is a completely new concept boasting the highest energy-efficiency ratio in its category. In combination with free-cooling technology in both self-draining and adiabatic versions, the NAX Inverter realizes a new system able to produce cold energy at low cost, further improving energy efficiency.
For air cooling, the ABF Inverter has undergone major changes. Already a popular unit for the cooling of bubbles in plastic film extrusion, Eurochiller has created a system called Airmix Kit to further improve performance through application of the free-cooling function. By using outside air when the temperature is lower than that of the required set-point, the free-cooling function is activated and the compressors automatically stop, taking advantage of a free energy source but with a very strict precision level thanks to control technology developed by Eurochiller. More on both developments can be found at Stand 10A76 at K. —Stephen Moore
Post new comment
