PEI Resin Plays Key Role in Enhancing Vehicle Fuel EfficiencyPEI Resin Plays Key Role in Enhancing Vehicle Fuel Efficiency
Sabic’s Ultem material is used in electro-hydraulic control valves for variable valve timing (VVT), variable displacement oil pump control (VDOP), and cylinder de-activation control (CDA), all of which enhance fuel efficiency and vehicle performance.
June 11, 2020
High-performance automotive component supplier Husco (Waukesha, WI) was an early adopter of Sabic’s Ultem polyetherimide (PEI) resin in automotive applications. It has been using unfilled and glass-reinforced grades for 12 years, during which time it has built up considerable expertise in design and production with these high-end materials. “We have been using Ultem resin to drive innovation in engineering design and automation,” says Matt Schmitz, the company’s Engineering Programs Director. “Our success is based on knowledge of the applications and systems at our customers, who we work with to co-develop new products for the next-generation of road vehicles.”
Husco has been developing and producing solenoid valves for a wide range of cylinder deactivation applications using Sabic’s Ultem resin. Image courtesy of Sabic. |
Husco, with production operations in several countries across the globe, is supporting major automotive OEMs in their developments. Its expertise in use of high-performance, lightweight materials is considered invaluable as OEMs work on new and innovative solutions for drive train and braking systems in future vehicles. The company continues to invest heavily to innovate in these areas.
Typical applications for Ultem resin developed by Husco are for components in their electro-hydraulic control valves. The application of those control valves are in variable valve timing (VVT), variable displacement oil pump control (VDOP), and cylinder de-activation control (CDA), all of which enhance fuel efficiency and vehicle performance.
Husco’s highest volume application is its range of cam phasing and VVT technologies. It has produced tens of millions of products in this family and continues to find new ways to optimize its product design and production system. These low-cost, lightweight valve technologies enable engines to maximize performance for specific loads and speeds.
The company was also an early innovator in variable oil pump control technologies. These products improve efficiency by allowing engines to scale their oil usage in response to driving conditions. And for over a decade now, Husco has been developing and producing solenoid valves for a wide range of cylinder deactivation applications. These valves control engine systems that turn specific cylinders on and off in order to maximize efficiency and performance.
Ultem resin is a family of amorphous PEI resins that offers outstanding elevated temperature resistance, high strength and stiffness, and broad chemical resistance. They provide an excellent balance between mechanical properties and processability.
Key benefits of Ultem resin include long-term heat resistance up to 180°C; outstanding strength and stiffness up to 200°C; dimensional stability over a wide temperature range; strength retention over long periods, and inherent flame resistance without additives.
Husco values Ultem resin for many reasons. Top of the list are its ease of use in injection molding and the absence of any requirement for such secondary operations as annealing; very low creep, which is invaluable in applications under virtually constant stress; and the freedom it provides for designers to create complicated parts.
Says Schmitz: “We require extreme precision and micron-level dimensional stability across a broad temperature range that starts at -40°C and goes up to well over +150°C in applications like engine valve components, which need to survive sometimes as many as 700 million cycles over their lifetimes and constant vibration loads. Ultem resin is the best thermoplastic we have found that meets those needs. The other major benefit offered with Ultem is in it being amorphous, which reduces impacts from process settings that may be seen with other high temperature rated semi-crystalline materials.”
“Just as valuable is the technical service that Sabic provides throughout the design, development and manufacturing stages,” says Schmitz. Husco makes some extremely complicated components, and is regarded as one of the most innovative application developers working in the automotive industry today. “We value any input from Sabic that helps us get the most out of its high-performance materials and allows us to optimize our innovations.”
Husco continues to plan for the use of Ultem resin in future applications. “We are pleased to hear that Sabic is moving ahead with capacity expansions in Singapore and in the US,” says Todd Dickrell – VP Purchasing. “We and our customers very much appreciate the capability that manufacturing locations around the world provide us in supply of Ultem resin.
