Film and fiber grinder
January 1, 2003
product_jan_02 (10K)The ReTech RG52FF rotary grinder is designed to shred flexible materials that tend to self feed. Especially suited for one-pass size reduction of films and fibers being reclaimed for extrusion, the FF Series has built-in metering capabilities and thermal monitoring controls. The unit uses two-stage auxiliary reduction, a reinforced close-tolerance screen, and a wedge-style fixed counter knife. Specifications include: 1000- to 4000-lb/hr throughput, 52-by-58-inch hopper opening, 3.5- to 6-cu-yd hopper volume, 15-inch rotor diameter, 74 main and 29 auxiliary cutters, 90- to 150-rpm rotor speed powered by a 150-hp drive motor, two-speed hydraulic feed ram, and a machine weight of 10,000 to 12,900 lb. The machine uses 460V, three-phase, 60-Hz power.
Vecoplan, High Point, NC
(336) 861-6070; www.vecoplanllc.com
