Canadian-based Macro Engineering & Technology Inc. has developed a new high speed coextrusion line for producing biaxially-oriented (biax) sausage casings.The line can be configured to produce coextrusion casing structures up to 11-layers using nylon, PE and EVOH. It can also be extended to allow processing of structures with PVdC. It produces casings with width calibers of 80 to 120 mm and thickness ranging from 40-50 microns. The line operates at speeds up to 170 m/min.
Macro launches new biaxially-oriented sausage casing extrusion line
Macro_CasingBubble.jpegMacro says the line can be readily converted to produce films for barrier shrink bag production.
The line includes a primary bubble forming section with a vacuum calibrator, orientation section with infrared (IR) sectional heaters and an IR annealing oven. The bubble diameters in each section are precisely measured and controlled to ensure consistent production quality. Macro says that operation of the line is complex so the company incorporated an advanced control system to assist operators. The control system contains recipes for automatic ramping up (and down) of the line speed with simultaneous adjustment up to 30 process parameters. Macro intends to add automatic gauge control to the system by 2015.
Macro Engineering & Technology is a global supplier of film and sheet extrusion systems that specializes in barrier film lines and custom engineered extrusion systems.
