Manifold for multiple regulator mounting
July 1, 2005
The QB3 is a closed loop pressure regulator with two solenoid valves, an internal pressure transducer, and electronic controls all integrally mounted to a volume booster. The pressure regulator can be used in extrusion, injection molding, and blowmolding applications. Up to four QB3 electronic pressure regulators can be mounted to a manifold which offers a common supply and exhaust port with individually controlled outlet ports to minimize plumbing and save space. The unit is capable of controlling pressure or vacuum electronically by accepting a command signal of either 0 to 10V or 4 to 20 mA. The pneumatic output is linear to the command input. An analog output of 0 to 10V is standard, representing actual pneumatic output.
Proportion-Air Inc., McCordsville, IN
(317) 335-2602; www.proportionair.com
