Reaction injection molding lines improve accuracy and maintenance
September 1, 2002
NP_Gusmer.jpgThe OmegaRim RX and RimCell RX reaction injection molding (RIM) lines now include Rexroth A2VK positive displacement axial piston metering pumps for volume and ratio accuracy, open construction and straight tubing runs for easy maintenance, and accurate digital flow readout that eliminates the need for wet calibration.
Additionally, the RimCell RX line has a mechanism that allows the motor to slide away from the pump, with a mounting bracket that doubles as a seal-changing workbench. The mechanism makes pump unbolting and extensive chemical tube disassembly unnecessary, and speeds pump seal replacement.
Gusmer Corp.
Lakewood, NJ
(732) 370-9000
www.gusmer.com
