The Troubleshooter: Essentials of the Injection Molding Process
Follow these guidelines to correctly validate your injection molding process and reduce defects and scrap.
Garrett MacKenzie
November 19, 2024
technician working on injection mold
Flash, splay, and shorts are among the defects that can show up when a validated molding process fails.Kemter/iStock via Getty Images
Machine and process troubleshooting are the most important factors in controlling process and reducing defects. Poorly performing presses lead to process variance and uncontrollable scrap events, and underperforming machine components can result in validated process failures. This article outlines key factors that can lead to unplanned down time and process inconsistencies.
Defining a validated process
Process validation entails two stages.
The first stage is developing a process that produces parts at efficiencies that meet the quoted cycle while producing 0 to 1.5% scrap — zero is always the true goal. Once this has been accomplished, the press must run eight hours with no adjustments made to maintain consistency. Then, all process setpoints are recorded and basic process monitoring variables are established. Mold setup variables also are recorded to ensure repeatability.
The second stage of process validation requires setting the mold exactly the same as in the initial setup. Input of press setpoints is identical to the initial press settings. True validation requires that second-stage startup produce good parts in three to five shots with minimal process adjustments. Once this is achieved, process monitoring data is recorded and process control limits are established. All key monitoring data is recorded for the purpose of having complex troubleshooting data for comparison.
With process validation defined, let’s look at some common defects that can come up when a validated process fails. Keep in mind that the first steps to take when a validated process is not working is mold cleaning and inspection followed by process verification.
Flash
A number of factors can lead to flash. The first step is to verify the process and inspect the mold for buildup. Drop hold and pack to zero to verify that fill-only is at 95 to 98%. Verify you are using the correct material and that there hasn’t been a lot change. Verify temperature actuals are the same as setpoint. Check to see if water is on, and water GPM is correct. Is tonnage correct, and has die height been set correctly? Are peak pressure and fill time within the process monitoring window? Are the platens parallel on all four corners? Inspect the mold, heat, and machine condition to find a solution.
Splay
Is the dryer working properly? Is the dryer supply hose hot and the return hose warm? Have you checked the moisture content of the material? Is the material correct or has the lot changed? Are mold and barrel heater setpoints correct? Is there a water leak on top of the mold? Has fill time changed and is it consistent? Is your screw recovery time staying consistent? Remember to look at all moisture- and heat-related variables when troubleshooting this defect.
End-of-fill burns
Burns at end of fill generally are directly related to injection speed or venting. Is your tonnage set too high? Is the mold vented at end of fill? Are the vents worn out? Is your fill time too fast when compared to process? Is your melt temperature correct? Is your injection transfer into hold pressure too low? Have you checked the material moisture content? Is your mold clean?
Shorts and unfill
Shorts and unfill are usually related to unpacked parts or poor heating. Do your hot runner temperatures equal your setpoints? Are your barrel temperatures correct? With pack and hold to zero, does your fill-only shot equal 95 to 98%? Is your fill time correct? Is your press consistently maintaining proper pressures and speed? Is your mold dirty, causing gas trap shorts? Is your shot size correct?  Review all variables related to part weight, temperature, and pressure.
A plethora of causes can lead to the defects outlined in this article. First steps are always to verify the mold is clean and the process and equipment have been set up correctly. Troubleshooting beyond that has a direct relationship to the 5 M’s — man, mold, machine, material, and method (process). Correctly reviewing the data and processes simplifies identifying the cause of common defects.
How to Fix Injection Molding Inconsistencies
How to Become a World-Class Injection Molder
Standardization Is Key to Consistent Injection Molding Processes
Separating Fact from Fiction in Color Molding
Developing Robust Maintenance Procedures in Plastic Injection Molding Operations
Setting Up Your Injection Molding Process for Success
A Primer on Plastics Processing Fundamentals
How to Interpret Plastic Injection Molding Data
How to Prevent Mold-Change Failures
Garrett MacKenzie
Garrett MacKenzie is the owner/editor of plastic411.com and a consultant/trainer in plastic injection molding. He has provided process-engineering expertise to many top companies, including Glock, Honda, Johnson Controls, and Rubbermaid. MacKenzie also owns Plastic411 Services, which provides maintenance and training support to Yanfeng Automotive Interior Systems, IAC, Flex-N-Gate, and other top automotive suppliers. He was inducted into the Plastics Pioneers Association (PPA) in 2019, where he serves on the Education Committee evaluating applications from college students seeking PPA scholarships. You can reach him via e-mail at [email protected].
