The Troubleshooter: Separating Fact from Fiction in Color Molding
How much do you know about efficient color mixing in injection molding operations? Take this quiz and find out.
Garrett MacKenzie
July 23, 2024
word quiz in speech bubble
Chee Siong Teh/iStock via Getty Images
Adding color to a natural material can lead to processing nightmares. Colors can be too dark or too light. Poor screw mix can lead to color swirls. Primary and neon colors can cause major scrap in color changes. Sometimes the color base material conflicts with the material being used because of the mix ratio, leading to lamination. Even splay can result from feeder introduction of colorant into a dried material. This article addresses common defects caused by misunderstandings and false information in a true or false format.
True or false: Dispersion discs adequately mix material.
False. Dispersion discs were an industry attempt to use a disc with multiple holes to improve mixing properties. Unfortunately, the discs are more prone to capture material contaminants as material is pushed through the small holes. The result often leads to shorts caused by increases in injection pressure as the holes in the disc get plugged.
This is also false. Mixing screws are a great selling point, but no data support the premise that scrap is eliminated. Changes in screw agitation can lead to other defects such as splay. Color dispersion is best improved through back pressure, barrel temperature, and screw speed.
Related:Top Tools for Injection Molding
True or false: Increasing barrel temperature improves color mixing.
Again, the answer is false. Increases in barrel temperatures could potentially reduce color scrap, but it it is important to remember that higher temperatures can lead to reduced shear in the compression zone. Lower feed zone temperatures might actually improve shear in the compression zone, leading to a better mix event.
True or false: Increased back pressure can improve color mixing.
This statement is in fact true. Back pressure is one of the primary components in correctly mixing color. It is important to note that setting back pressure too high can lead to higher compression zone temperature. Higher temperatures can reduce shear. Ultimately, this can lead to poor mixing.
True or false: Lower screw speeds can improve mixing results.
This is, indeed, true. When evaluating your mixing scope, it is important to evaluate screw speed vs. screw rotate time. Slowing screw speed to accomplish a screw rotate time 1.5 to 2 seconds shorter than cooling time can lead to an improved mixing event. Slower screw speeds result in a lower screw heat soak temperature, which can increase shear and mixing. Just remember that lower heat soak events could lead to shorts requiring adjustments to other setpoints.
True or false: Regrind has little to no effect on mixing approach.
Nope, that’s false. Scrap being ground has been molded at a specific color ratio. Materials with an introduction of regrind into the normal mix ratio are incorrect and can lead to a significant change to the overall color scope. Regrind ratios will require an analysis of how much regrind can be added into the virgin mix before the end color meets customer requirements.
True or false: Color mixing saves money.
This is debatable. There are companies that develop a solid approach using blenders and color feeders and effectively use color mixing equipment to produce premium parts with few to no defects. It is important to note that the higher quality class your customers require the higher the difficulty level to be profitable.
Production efficiencies require achieving 100% of quoted cycle time and little to no scrap. High scrap events lead to longer production events and an increase in mold changes to meet customer demands and delivery. Color mixing is achievable if your team has a full understanding of the mixing equipment it uses and of the process changes needed to eliminate scrap. Companies that struggle with a color mixing environment might be better off using pre-colored materials.
Developing Robust Maintenance Procedures in Plastic Injection Molding Operations
Setting Up Your Injection Molding Process for Success
A Primer on Plastics Processing Fundamentals
How to Interpret Plastic Injection Molding Data
How to Prevent Mold-Change Failures
Garrett MacKenzie
Garrett MacKenzie is the owner/editor of plastic411.com and a consultant/trainer in plastic injection molding. He has provided process-engineering expertise to many top companies, including Glock, Honda, Johnson Controls, and Rubbermaid. MacKenzie also owns Plastic411 Services, which provides maintenance and training support to Yanfeng Automotive Interior Systems, IAC, Flex-N-Gate, and other top automotive suppliers. He was inducted into the Plastics Pioneers Association (PPA) in 2019, where he serves on the Education Committee evaluating applications from college students seeking PPA scholarships. You can reach him via e-mail at [email protected].
