Carbon fiber, PEEK combine in lightweight aerospace compositeCarbon fiber, PEEK combine in lightweight aerospace composite
Weight reduction and lean manufacturing are key focuses in the aerospace sector as designers seek to the reduce operating costs of their aircraft. Consequently, thermoplastic composites that can perform with at least the same assurance as traditional metals and thermosets are in demand.
In response to these requirements, Tri-Mack Plastics Manufacturing Corporation, a molder of high-temperature engineering thermoplastics located in Bristol, RI, has developed Victrex PEEK (polyetheretherketone) composite manufacturing capabilities and produced brackets for use in aircraft structural applications. The brackets weigh approximately 45g each, and are employed in primary and secondary structural applications in commercial and military aircraft. Tri-Mack specified the material due to its technical features and proven track record of 25 years of use in injection molded aerospace components.
peek
PEEK/carbon fiber thermoplastic composite offers 70% weight saving versus stainless steel, with better manufacturability to boot.
The composite has a density of 1.6 g/cm3 versus 8 g/cm3 for stainless steel. Based on current fuel prices, the removal of one kilogram (2.2 lb) of weight from a short-range aircraft can save airlines up to $100 in annual fuel costs. "Assuming that the composite brackets can remove 100 kg (220.5 lb) of weight, an airline with 500 short-range aircraft could save up to $5 million per year in fuel costs by making the switch from metal," explains Ralf Weidig, Composites Business Leader for Victrex (West Conshohocken, PA).
Besides up to 70% weight savings compared to metals such as stainless steel, aluminum, and titanium, the innovative composite manufacturing process used by Tri-Mack provides several benefits leading to faster part manufacturing cycle times compared to thermosets. "Thermoset composite parts typically take several hours to complete," said Tom Kneath, director of sales and marketing at Tri-Mack. "The Victrex PEEK composite brackets have manufacturing cycle times measured in minutes. That speed, paired with the ability to recycle the material for other applications, takes us to a whole new level of processing efficiency that isn't achievable with thermosets."
Component integrity is also critical to keeping aircraft in service in order to minimize maintenance and downtime. Thermoplastic composites made from Victrex PEEK can provide the chemical and corrosion resistance to jet fuel, hydraulic fluid, de-icing solution, salt, steam, water and other commonly used service fluids that would typically undermine the longevity of metals. "Victrex PEEK composites can offer between four- and five-times higher fatigue strength, specific stiffness, and specific strength when compared to traditional metals such as aluminum," says Weidig. "These mechanical properties along with vibration and noise dampening improvements make Victrex PEEK composites an attractive and viable solution for engineers looking to replace heavy metals and thermosets."
