Product News - Polymer Composite Replaces Aluminum In Dry Ice BlastingNozzle
Polymer Composite Replaces Aluminum In Dry Ice Blasting Nozzle
PN 5-11/99The 523 Stealth nozzle, for use with manufacturer Cold Jet's single-hose CO2 dry ice blasting equipment, is made using a polymer composite for heat tolerance, strength and light weight. This nozzle will replace the aluminum 523 SF nozzle in all non-foundry orders.
Cold Jet says the new nozzle takes the 'blast aggression' of the aluminum nozzle and makes it more ergonomic and durable. It is also half the weight of the aluminum nozzle and has inherent thermo-insulating properties to keep it warmer, thereby reducing frost build-up. It can withstand temperatures to 350 F and has a static field dissipation feature for safety. The new nozzle is said to be priced around  25% less than the aluminum unit.
Cold Jet, Inc.
Loveland, OH
