90-Deg Lift And Transfer Capability Added To Chain Transfer System
August 1, 2001
August, 2001
Pallet Conveying:
90-Deg Lift And TransferCapability Added ToChain Transfer System
0801pn-1.jpgAlba Manufacturing's 90-deg chain transfer system for conveying palletized loads is said to be guaranteed for 1 million maximum-load cycles. The system is designed to lift up to 3 tons.
Thru- and in-frame chain transfer systems are available in widths from 48 to 60 in. and load capacities of 2000, 4000 or 6000 lb. Units are supported by a welded structural steel frame for rigidity, unlike bolted assemblies that can loosen due to vibration.
Systems are available in two- and three-strand transfer-drive configurations. Reversible transfer drive permits pallet movement in either direction, perpendicular to the source conveyor line. The roller-driven conveyor bed uses 2.5-in.-dia rollers spaced from 3.25 to 6 in. on-center, depending on the model. Conveyor elevation is customer-specified.
Optional equipment includes photoeyes, up/down limit switches, brake motor and electrical controls. Use the Key Contact Directory onp 51 to call about pricing.
Alba Manufacturing Inc.
Hamilton, OH
