A.R. ENG. MACHINE INC.
May 1, 2000
Booth N-5066
npe1.jpgWhat's Hot! A back-to-back dual surface winder is a semi-automatic device with a 124-in. maximum web width. Maximum roll diameter is 45 in. Other features include: PLC and sensor control timing (the PLC is built for future installation of a hydraulic unloading arm), dancer assembly for film tension control, secondary nip drive incorporated through the motor, rubber winding drum with diamond patter to aid in spreading film and web flatness, pneumatic assembly with band cylinders for precise winder arm movement, control panel, heavy-duty construction with 1-1/4-in. plate for winder side plates to prevent vibration, two 3 hp torque motors with gear boxes, two emergency stop buttons, counter, slitting knife and pneumatic cutting knife and automatic roll change.
Existing Products On Display A range of blown film equipment will be shown, including winders, air rings, screen changers and die packages.
Cool Booth Details A small blown film line will be running. Circle 200
Booth Personnel Alberto Ruetalo
Key Contact Alberto Ruetalo, Pres. ­ Tel: 905-602-5828; Fax: 905-602-5829;
E-mail: [email protected]; Web Site: www.arendmachine.com
