ADHESIVE SYSTEMS TECHNOLOGY CORP.
Booth E-14326
What's Hot! Company will display its DMS (Dynamic Mixing System) Series of equipment for metering and dispensing two-part urethane and silicone foams. Units use positive displacement piston and gear metering pumps and can process abrasive and nonabrasive materials. System comes with a material transfer pump, material agitation and nucleation, temperature controls and ratio check.
Meter capacity operating range is 2 to 120 cc and viscosity range is 1 to 2 million cps. Options include automatic purge, X-Y-Z motion, turn table, automatic refill of material and ratio monitor control.
Existing Products On Display include the GMP 075, 100 and 200 gear metering and dispensing systems for two-component urethanes and epoxies, the BH-CMP 632 adhesive dispensing system, the PH-CMP 424 and 632 adhesive dispensing systems, dual hydraulic drive-dispensing systems for single or plural components and a range of other two-component adhesive metering and dispensing systems. Circle 202
Booth Personnel Steve Anderson, Robin Murphy, Stephen Hirt
Key Contact Stephen Hirt, Mktg. Mgr. ­ Tel: 612-721-8685; Fax: 612-721-1736;
E-mail: [email protected];
Web Site: www.adhesivedispensers.com
