AXEL PLASTICS RESEARCH LABORATORIES, INC.
May 1, 2000
Booth E-13754
npe5.jpgWhat's Hot! A range of mold release agents and internal lubricants from the manufacturer's MoldWiz and XTEND lines will be on display, including:
* MoldWiz INT-VP250 internal lubricant is said to improve resin flow and additive dispersion without weld/knit lines on automotive panels.
* MoldWiz INT-40DHT internal lubricant and processing aid is said to eliminate the need for external mold releases. It is tailored for PES and other engineering resins processed at temperatures between 500 and 700 F.
* MoldWiz INT-PUL14 is designed to optimize pultrusion line speed while minimizing corrosive effects on dies.
* MoldWiz INT-1117EL processing aid is designed to improve release of many of the new EPDM elastomers.
* XTEND 800 semi-permanent mold release agent (Apr '00 PA, p 72) is said to improve RTM processing with advanced multiple insert technology capability.
* XTEND W7200 semi-permanent aqueous external mold release agent (Sep '99 PA, p 73) is said to form a uniform cured film upon drying and is designed for molding epoxy, polyester and rubber. Circle 214
Booth Personnel Nancy Teufel
Key Contact Nancy Teufel, Mktg. Dir. ­ Tel: 800-332 AXEL (2935); Fax: 718-565-7447;
E-mail: [email protected];
Web Site: www.axelplast.com
