Double-belt lines make panel production easy
A 300 m-long double-belt production line produces industrial and cold-storage prefabricated sandwich panels from polyurethane (PUR) or polyisocyanurate (PIR) at up to 20 m/min. An optional duplex high-pressure metering unit permits cleaning of the mixing heads without shutting down the machine. The core of the unit is a 40-m-long heated, slat-type, double-belt conveyor for curing and calibration.
Meanwhile, Hymmen''s improved IsoPress KSF double-belt line for various types of sheet products has lower vertical space requirements and needs no special foundation. It uses a combination of isobaric pressure and temperature control to insure uniform panel quality. Hymmen GmbH, Theodor-Hymmen-Str. 3, D-33613 Bielefeld, Germany www.hymmen.com; Siempelkamp Handling Systeme GmbH, Hans-Urmiller-Ring 6, D-82515 Wolfratshausen, Germany www.siempelkamp.com
