Gyratory sifters geared for high-volume usage
Sweco has introduced gyratory sifters used for high-capacity dry screening in industrial, recycling, and agricultural markets. The rectangular separators are for high-volume dry applications requiring larger screen surface areas. The GyraMax units feature a center-mounted vibratory drive system that produces uniform gyratory motion across the length of the screen deck with adjustable speed and stroke. Speed can be adjusted from 150 to 400 rpm and the stroke from 5/8 inches to 3 inches. The drive system produces better product fluidization; superior screen cleaning; does not require counterbalancing; is lubricated for life; and backed by a three-year warranty. High temperature applications of up to 250 degrees F are possible. Sweco, PO Box 1509, Florence, KY 41022-1509 www.sweco.com.
