IM Interface Kit For Installation Of Monitoring/ Control Equipment
12.jpgRJG's REDI Kit is a machine interface designed to allow any injection molding machine to be pre-configured or retrofit for easy installation of RJG's monitoring and control equipment.
With the kit, participating injection molding machine manufacturers can customize machine inputs and outputs to a standard connector package for use specifically with RJG's DARTScanner and DARTPak process data collectors. This facilitates the implementation of cavity pressure control and monitoring.
RJG says it is working with various OEMs to provide standard interfaces for process monitoring, automated abnormal part containment and cavity pressure control. When purchasing a new injection molding machine, molders should ask for the REDI Kit option. If the OEM is not currently using this option, contact RJG and they will work with your supplier to make this seamless interface possible.
RJG Inc.
Traverse City, MI
