Infrared strip heaters use halogenInfrared strip heaters use halogen
March 1, 2004
The StripIR series of strip heaters use parabolic reflectors to apply heat to narrow strips of material. The heaters are adjustable and can be installed in a variety of configurations. The lamps reach 90% of full operating temperature within 3 seconds of a cold start. The radiant energy dissipates to 10% 5 seconds after the power supply is disconnected.The StripIR Model 4184 uses T-3 style halogen lamps backed by a ceramic reflector to provide heat. The StripIR Model 5305 uses a tubular quartz T-3 style halogen lamp backed by an aluminum reflector. A water-cooling system prevents the reflector from overheating and allows continuous operation.
Research Inc., Eden Prairie, MN
(952) 941-3300; www.researchinc.com
