Low- And High-Rate Feeders Added To Line
November 1, 2001
November, 2001
Materials Handling:
Low- And High-Rate FeedersAdded To Line
AccuRate has added the small LS Mechatron and the larger HC Mechatron to its line of feeders. Profibus, DeviceNet, Modbus and Ethernet communications interfaces are optional on all units.
Low-rate feeder, the LS Mechatron, has output rates up to 23 cu ft/hr and is said to be especially suited to feeding cohesive materials such as Kevlar, wood flour and color pigments. Unit has a conical, stainless steel hopper, two-stage material agitator and a dual load cell weigh section.
Integrated, pre-wired volumetric or gravimetric control packages are available. The unit can be disassembled, cleaned, reconfigured and serviced from the non-process side. Three sizes of extension hoppers are also available: 1, 2.25 and 3 cu ft. 360-deg connection clamps are said to eliminate material leakage. Circle 104
Feed rates in excess of 1100 cu ft/hr are claimed possible for the HC Mechatron feeder. Both volumetric and gravimetric configurations are available and both feature a cast aluminum and stainless steel frame, conical flexible hopper with external paddle agitation, 2 or 3 hp ac drive packages and integrated and pre-wired controls.
Like the LS above, this unit can be disassembled, cleaned, reconfigured andserviced from the non-process side and features 360-deg connection clamps to eliminate leakage.
Extension hoppers are available in 10-, 20- and 50- and 100-cu ft sizes.
AccuRate,
A Unit of Schenck AccuRate
Whitewater, WI Circle 105
