Movable controls add to extruder's flexibility
June 1, 2004
Extrusion machine operators who must be near the die area while setting up the process parameters can now do both simultaneously thanks to a swing-arm control that can be maneuvered into various positions. In coextrusion applications, the coextrusion controls for the Model TL-350 thermoplastic extruder from Diamond America Corp. are located in the same panel as the main extrusion controls.
The swing-arm unit can be applied to any size extruder, but the TL-350 is a 3.5-inch, 30:1 extruder. Like all Diamond extruders, this model has a four-bolt swing gate, easy-close hopper slide, and a spill-proof hopper drain. The front barrel support has bi-directional adjustment for easier alignment, and the barrel reduces deflection, helping, in turn, to reduce screw and barrel wear. Diamond America Corp., Tallmadge, OH; 330-633-9959; www.diamondamericacorp.com
