Multi-Spindle Winder Can Run Alone Or With Other Modules
January 1, 2001
jan01_15.jpgModel MS104 from Progressive Machine is a multi-spindle, modular winder that, by design, can run independently, but can also be coupled with other modules to control the entire take-up line.
Unit features a simple operator-control cluster. It can handle a package of 18 in. dia and 12 in. wide and up to 80 lb. The adjustable traverse assembly and lay-on roller guides allow the system to be adapted to either spool or coil winding of flat materials. Standard tension range is from 8 to 32 oz with a maximum line speed of 500 ft/min.
Options include digital counters, special material guides and coatings, spool/core/coiling adapters and an ultrasonic tension control. Pricing is available directly from the company (check out the Key Contact Directory on p 36).
Progressive Machine Co., Inc. - Ringwood, NJ
