PIM troubleshooting
May 18, 2000
This chart provides information on PIM troubleshooting: molding problems, analysis, causes, and remedies. The information comes from Thermat Precision Technology Inc. (Corry, PA).
Problem | Analysis | Cause | Remedy |
· distortion· flash· incomplete filling· separation· sticking | · injection pressure profile: high/no peak in transition period | · poor transition from speed (filling) to pressure control (packing) | · adjust transition point/ use different transition trigger· reduce final injection speed |
· flash· porosity and voids· sink marks | · cavity pressure profile follows injection pressure profile closely in packing period· low injection pressure during filling | · powder mixture is too liquid; melt temperature is too high· filling by jetting | · reduce nozzle/barrel temperature profile· check actual melt period temperature in nozzle/barrel |
· cracking· distortion· incomplete filling· inconsistent surface finish· lamination· porosity and voids· rough surface texture | · large difference between injection pressure and cavity pressure profiles· high injection pressure during filling | · powder mixture is too viscous, melt temperature is too low· filling by multiple jetting | · increase nozzle/barrel/ mold temperatures· check viscosity of melt by extrusion (should be liquid, but not too thin)· adjust filling speed profile |
· cracking· sink marks | · drop in injection pressure later in packing cycle causes drop in cavity pressure | · molded compact is cooling and shrinking, but gate has not frozen off yet after packing | · increase packing times for the early stages of the packing pressure profile |
· sink marks· lamination | · large difference between injection and cavity pressure profiles in middle of packing cycle | · gate has frozen off, but compact is still liquid, cooling and shrinking· reduce initial (low- pressure) packing period for skinning | |
· distortion · rough surface texture· weldline cracking | · large difference between injection and cavity pressure profiles at proper melt viscosities | · melt is solidifying before mold cavity is completely filled | · increase mold temperature· increase injection speed profile |
· distortion· flash | · injection pressure for initial packing much higher than for end of filling | · initial packing pressure unnecessarily high | · reduce initial packing pressure |
· cracking· distortion· separation· sticking· weldline cracking | · injection pressure profile high during filling | · filling speed profile not adjusted according to viscosity/shear rate behavior | · adjust injection speed profile to reduce injection pressure during filling |
· part/sprue fracture during ejection | · injection pressure much higher than cavity pressure in packing | · packing pressure higher than gate can transfer | · reduce packing pressure profile |
· porosity and voids | · drops or peaks in injection pressure profile during filling· entrapped air in metered feedstock in front of screw | · adjust metering back-pressure and speed· check feedstock shape and size consistency | |
· cracking· sink marks· surface defects | · injection pressure profile for packing lower than for end of filling | · insufficient packing pressure to overcome feedstock viscosity | · increase packing pressure profile |
