Product News - Hot Sprue Bushings Can Directly Replace Cold SprueBushings
Hot Sprue Bushings Can Directly Replace Cold Sprue Bushings
The new DSR Series 20 and Series 30 hot sprue bushings from Osco feature interchangeable nozzle tips and heaters. They are designed to fit into 3/4- or 1-in. nozzle bores. They will fit into standard mold bases and can be retrofit without re-machining.
Available are the Series 20 with AF (absolute flow) tip, the Series 30 with AF tip and the Series 30 with FB (full body) tip for low-vestige applications.
For under $1000, customers get a nozzle with 230-v heater, thermocouple and tip, as well as a temperature controller with cable and mold end connector.
Osco Inc.
Rochester Hills, MI
