Product News - Single-Piston Continuous Screenchanger
July 1, 1999
The SP-C single-piston continuous screenchanger from Maag features a seal-less piston-type design and has two breaker plates. This allows it to be used wherever a slide-plate screenchanger is used or where continuous operation is a benefit.
Unit has a 7500 psi extrusion pressure rating and extruder screw roll-through capability. It is available in screen diameters up to 13.38 in. and capacities of up to 40,000 pph.
Other standard features include a solenoid-activated hydraulic cylinder with remote push-button control, easily accessible top-mounted heaters with insulated housing and three vent grooves for complete de-aeration after screen change.
Options include a moving cart of mounting components, automatic piston positioning and valving for precise control and custom adapters.
Pricing depends on size and options chosen, but a 4.5-in. system starts at just under $20,000.
Maag Pump Systems Textron Inc.
Matthews, NC
