Product News - Two-Stage Rotary Grinder Processes Up To 1000 lb/hrProduct News - Two-Stage Rotary Grinder Processes Up To 1000 lb/hr
August 1, 1999
The RG42 two-stage rotary grinder uses an integrated, two-pass process to first reduce scraps to a homogenous consistency and then perform final reduction down to 1/4- to 3/8-in. particles. Throughput is rated at 300 to 1000 lb/hr.
This compact model has a 42- by 48-in. hopper opening and a hopper volume of 2 cu yd. Rotor diameter is 15 in. and rotor speed is 125 rpm. It has 32 cutters and a 40 to 75 hp motor. Prices start at $130,000.
Other features cited by the manufacturer include LED monitoring; easy accessibility; tramp metal protection; a 3-hp, two-speed hydraulic process ram; four-way indexable cutting inserts; low noise (60 to 70 dbA); stress-relieved shell and frame; power belt rotor drive; oversized gearbox; heavy roller bearings; and PLC control panel.
ReTech Industries, Inc.
High Point, NC
