PVC plugs prevent pollution transgressionsPVC plugs prevent pollution transgressions
Hydraulic oil through the floor drain leads to a financial penalty for polluting. Ryno drain plugs help processors comply with environmental regulations by providing a quick yet reliable means of ensuring that any spilled or leaking liquids cannot enter floor drains.
September 27, 2010
Made in the U.S. by Ryno Rollers (Auburn, Washington), the drain plugs are made of PVC compound with exceptional tensile strength and durability, producing an inherently tacky surface that will temporarily bond to both smooth and uneven surfaces. Cleaning with soap and water does not diminish their adhesive properties, and the plugs can be reused. Ryno Rollers vice president of sales and marketing Roger Giza comments: "Ryno drain plugs quickly and easily prevent chemicals from entering the waste processing system. They should be kept in chemical storage areas and near drains to ensure availability for immediate use in case of spills or leakage. The plugs are available in four sizes, to fit drains ranging from 2 inches to 5.5 inches (50 mm to 140mm)." -[email protected]
