Pyrometer Checks Temperatures In A Range Of ApplicationsPyrometer Checks Temperatures In A Range Of Applications
February 1, 2000
The Dyna-Temp pyrometer is available with temperature ranges from -280 to 2000 F. Unit has a self-test diagnostic circuit so users can verify accuracy with the push of a button.
All temperature readings aredisplayed on a 1/2-in. LCD. The housing is powder-coated aluminum.
Complete kits with the Dyna-Temp pyrometer, sensors and a carrying case are standard or you can tailor a kit for specific applications. Optional is athermocouple five-input switch, peak reading with memory and magnetic backing.
Electronic Development Labs, Inc.
Danville, VA
