Redesigned, user friendly temperature control
May 1, 2005
A redesigned temperature control is available in standard or customized form, and is manufactured at the company?s newly certified ISO 9001:2000 facility. The user-friendly control, with an intuitive soft-touchscreen control panel, incorporates a low-watt density incoloy heater ranging from 9 to 24 kW. Incoloy resists corrosion better than copper or stainless. A premium quality solenoid valve ensures precise temperatures.
High capacity pumps, from 3?4 to 71?2 hp, come with bronze or stainless impellers and ensure turbulent flow. The pump seal is made of leak-resistant EPDM carbon-silicon carbide. A seal flush line ensures continuous flow across the seal to remove contaminants and extend seal life. The leak-proof, twin-cast tank/pump assembly eliminates pipe fittings and flow restrictions and comes with a lifetime warranty.
An adjustable bypass water supply pressure switch prevents operation at low supply pressure and a bypass line protects the heater and pump if process flow is shut off. The temperature control is designed for easy maintenance with electrical components mounted in front and cabinet panels removable from the side, top, and front.
Berg Chilling Systems Inc.
Toronto, ON
(416) 755-2221; www.berg-group.com
