Rigid 20 KHz welding press
March 1, 2005
The Model 2055, 20-kHz, pneumatically actuated ultrasonic welding press was designed for rigidity and is said to minimize deflection and enhance precision. The rigid base casting has an integrated hub, increased column diameter and column wall thickness, increased throat depth for larger tooling capability, CNC precision-machined components, and THK brand rails and bearings. Features include an inline 2.5-inch bore, a 4-inch stroke pneumatic cylinder (or an optional 6-inch stroke), speed controls, and a pressure regulator with gauge. Quick-release column clamps and a head-adjust hand wheel with a counterbalance head spring are included to streamline tooling setups and changeovers. A high-efficiency snap-in converter rotates 360° to simplify radial horn alignment. Distance-controlled welding in incremental and absolute modes is possible with the optional linear encoder.
Sonics & Materials Inc., Newtown, CT
(203) 270-4600
www.sonics.biz
