Robot is an adept overhead moverRobot is an adept overhead mover
Adept Technology, Inc. (Pleasanton, CA) has debuted the Adept Quattro s800H with high throughput capabilities for applications with larger work space requirements. The unit is a parallel robot specifically designed for high-speed applications in packaging, manufacturing, assembly, and material handling, boasting a 1600-mm work envelope. The s800H is said to be an ideal overhead-mount robot when smooth motion, high throughput, and the ability to reach a large work space are critical for project success.
December 6, 2010
8 Min Read
Adept Technology, Inc. (Pleasanton, CA) has debuted the Adept Quattro s800H with high throughput capabilities for applications with larger work space requirements. The unit is a parallel robot specifically designed for high-speed applications in packaging, manufacturing, assembly, and material handling, boasting a 1600-mm work envelope. The s800H is said to be an ideal overhead-mount robot when smooth motion, high throughput, and the ability to reach a large work space are critical for project success. The patented four-arm design contributes to reduction of the power consumption by 23% when compared to alternate kinematic solutions. The Adept Quattro is powered by ultra-compact controls and embedded amplifiers, which reduces cycle times and improves footprint efficiency. —[email protected]
