Servo-drive ultrasonic welder has smaller footprint, greater accuracy
Dukane Corporation (St Charles, IL) has introduced a servo-drive series of ultrasonic welders: the iQ Series. The integrated all-electric servo technology eliminates the variability associated with pneumatic press components resulting in improved process repeatability and accuracy. This high repeatability reportedly results in fewer rejects for manufacturers.
December 30, 2014
Servo-driven ultrasonic welder raises weld accuracy stakes. |
Dukane's welding system addresses the need of an 'out of box' 'plug and play' servo-driven ultrasonic welder. Since most components such as the generator/power supply built-in, the welder has fewer cables, is very easy to install and provides a smaller footprint.
In a smaller footprint the welder reportedly provides the efficiency and reliability of the digitally-controlled, Multi-Core iQ Series power supply with the precision of an advanced servo press. Further, Dukane's Melt-Match technology precisely controls the collapse speed profile during the weld and precisely matches the collapse speed during the melt phase. Thus, the ultrasonic propagation penetrates deeper into the bond area and the affected heat zone is larger, resulting in superior bond strength.
The Integrated Servo Welding system has the flexibility to connect with any computer that has Dukane's iQ Explorer software. This allows access to the weld data, machine controls and storage of machine setups on the local area network or via the Internet for remote locations.
Troubleshooting of equipment and applications can also be performed from anywhere in the world. Integrated Servo is also FDA-compliant and features a robust mechanical design. There are no operator-accessible settings and all mechanical adjustments require a tool.
