Single hot runner nozzlesSingle hot runner nozzles
May 1, 2004
The Series Z 3410, Z 3440, Z 34201, and Z 34203 single hot runner nozzles are said to have an improved thermal conductivity. The nozzle heaters used in the Z 3310 Series are used, which are protected by a mechanically stable, heat-reflecting sleeve. The adapted coil density of the heater yields an even heat profile along the melting channel. The temperature is controlled through the arrangement of the FeCuNi thermocouples at the nozzle tip. The new single nozzles are offered in four versions: the Z 3410 with a standard carbide tip, the Z 3440 with an open carbide tip, the Z 34201 with a copper beryllium torpedo tip, and the Z 34203 with a carbide torpedo tip.
Hasco America, Arden, NC
(828) 650-2600; www.hasco.com
