Spin welder for big partsSpin welder for big parts
May 1, 2004
Providing the ability to spin weld large parts up to 30 inches in diameter, the SW 950 Spin Welder rounds out a line of secondary assembly equipment, joining heatstaking, and ultrasonic, vibration, and hot-plate welding. Spin welding joins plastic components that are spherical or cylindrical in shape by using frictional heat that's generated at the mating surface by spinning one part above a fixed part. Functional with a broad range of thermoplastic resins, the technology can create hermetic seals.
The SW 950 uses servopower for the spin and z axes to create greater precision. A machine/operator interface handles all machine parameter adjustments, and part orientation can be controlled to ±1 degree over a 30-inch part. Spin-axis speeds are adjustable in 1-rpm increments up to 3000 rpm. The servodrive keeps the spin axis constant regardless of load, and the vertical feed rate is adjustable in .001-inch increments. By varying the upper tool's home position, operators can lower the starting point and decrease cycle time. Plastic Assembly Systems, Milford, CT, 866-882-1701; www.heatstaking.com
