Stainless steel manifolds offer large inlet sizes
March 1, 2002
The swaged end design of Smartflow stainless steel manifolds offers large inlets for improved flow. The manifolds facilitate routing and metering of multiple flow streams and are suitable for use in injection molding machine cooling water loops, lubricant oil systems, blending systems, coolant systems, and packaging machinery.
The manifold is made of corrosion-resistant stainless steel. Standard inlet sizes are 1 inch and 1.5 inches NPT. Custom inlet and port sizes and fabrication are available. Manifolds are rated for 250F (121C) maximum, 125 psig maximum for use with air or inert gas, and 250 psig maximum for use with liquids such as hydraulic oil, water, or benign fluids. Mounting options include inline, bulkhead, pipe stanchion, or rack mount.
Standard or customized port patterns and sizes of .25 to 1 inch allow mix and match configuration with electronic and mechanical flow meters, quarter-turn ball valves, dial thermometers, pressure gauges, quick-connect hose couplings, hose barbs, or process pipe fittings.
Burger & Brown Engineering Inc.
Olathe, KS
(800) 764-3518
www.smartflow-usa.com
