Steel water manifolds with accessory ports
September 1, 2006
T he new line of manifolds features large-diameter end ports and accessory ports for pressure or temperature gauges. Heavy gauge steel with threaded couplings welded in place make up these manifolds. Each is tested to 120 psi (water or coolant only). They are easily mounted to mold platens or the temperature control unit with pre-drilled mounting brackets.
New features of the manifolds are two accessory ports of each manifold, and larger diameter end ports that provide greater water flow. If you wish to visually monitor water pressure or temperature, you can do so as each manifold includes 1?4-inch NPT accessory ports. The 11?2-inch end ports help decrease cycle times by providing more efficient water distribution.
EMI Plastics Equipment
Wickliffe, OH
(800) 543-6169
www.emicompanies.net
