Technology Notebook: Maximizing heater performance: 10 tipsTechnology Notebook: Maximizing heater performance: 10 tips
July 8, 2006
Examples of various products that failed as a result of high temperatures or contamination.This sheath deteriorated to the extent that liquid entered the heater. During subsequent heating cycles, the weakened sheath split open due to pressure buildup. |
Most plant engineers don?t give too much thought to the heaters operating within their processes and applications?unless those heaters fail, require significant maintenance, or cause other problems. However, heaters play an integral role in many applications, so heater problems can easily lead to much larger headaches.
Fortunately, following a few simple guidelines not only reduces the likelihood of heater-related issues, but can also have a significant positive impact on the efficiency of systems and reduce maintenance requirements and costs. This is especially true in plastics processing applications such as injection molding, blowmolding, and extrusion where temperature control and heater performance is a critical parameter in influencing throughput and yield. Below are 10 ways to maximize a heater?s service life and performance.
1. Guard against heater contamination. Contamination is the most frequent cause of heater failure. As heaters expand and contract during cycling, they often draw in organic or conductive materials, which can lead to an arcing failure between individual heater windings or between heater windings and the electrically grounded outer heater case. If allowed to collect at the lead end of a heater, contaminants can also cause electrical shorts between power pins. It?s important to keep lubricants, oils, low-temperature tapes, or processing materials out of contact with the lead end of the heater. One remedy is to employ moisture seals.
2. Protect leads from damage by high temperatures and excessive movement. Standard fiberglass-insulated lead wire may be used in applications with ambient temperatures up to approximately 500ºF. If a lead will be exposed to higher temperatures, high-temperature lead wire or ceramic bead insulation should be used. An unheated section of the heater, extending away from the heated region of the system, could enable the leads to run at a beneficially cooler temperature.
When heaters are mounted in moving machinery, it?s essential to anchor the leads to prevent them from being damaged. Specify a lead protection option.
3. Heater selection and sizing are important. Match a heater?s wattage as closely as possible to the application?s actual load requirements to limit on/off cycling. For fitted-part applications, specify the hole or other application feature size such that the heater can be appropriately sized to optimize the relationship between the heater and the application. A tight fit minimizes air gaps and reduces the instances of hot spotting. This consideration is especially important for band heaters used to heat plastics injection molding and extrusion barrels, where the band heater geometries often have to take other barrel mechanical features into account.
4. Ground the equipment. It?s common sense and a safe practice to electrically ground all equipment on which the heater is used. Grounding protects the plant and personnel in case of any electrical failure in the heating system.
5. Regulate voltage. Ensure that a heater?s rated voltage matches the available voltage supply. Wattage increases or decreases as the square of the change in voltage applied to a heater. For example, a heater rated for 120V, 1000W connected to a 240V supply will generate four times the rated wattage output or 4000W. This will cause a heater to fail fairly quickly, and may cause significant damage to the attached equipment.
6. Prevent excessive cycling. Excessive cycling can be very detrimental to the life of a heater. The worst cycle rate is one that allows full expansion and full contraction of the heater at a high frequency (approximately 30-60 seconds on/off). This problem can be eliminated by using silicon controlled rectifier (SCR) controls with either zero-cross or phase-angle firing, operating on a variable time base of less than one second. A solid state relay using SCRs operates on a one-second time base. This reduces the temperature difference between the overshoot and droop points and increases the life of the heater. The life-shortening effects of cycling can also be nearly eliminated by using solid-state controls with voltage or time-proportioning outputs. Even with simple on/off controls, much less frequent cycling can be achieved by closely matching the total wattage to the actual requirements.
7. Ensure that the sheath material and watt density ratings are compatible with the material being heated. This is absolutely critical to ensure long heater life and healthy processing equipment. When heating solids such as metals, the operating temperature and heater-to-part fit drive sheath material and watt density choices. Carbon steels, aluminum, silicone rubber, and so on are fine for lower temperatures up to a few hundred degrees. But as temperatures increase beyond this point, sheath material choices become limited to galvanized or stainless steels and other higher temperature metal alloys. As temperature also increases, the watt density must decrease accordingly, otherwise the internal resistance wires will oxidize quickly and fail prematurely. A good heater-to-part fit ensures proper heat transfer and does not force the resistance wires to overheat.
For liquid heating, the prime driver for materials and watt density selection is the fluid material and flow rate. Water can easily handle 60-100 W/in2 using a copper sheath, whereas a 50/50 water/glycol mix can only handle 30 W/in2 and will be fine using a steel sheath.
8. Mount immersion tank heaters horizontally near the tank bottom. Placing heaters horizontally and near tank bottoms maximizes convective circulation. Vertical mounting is only advisable when limitations, such as space restrictions, prohibit horizontal orientation. But whether a heater is mounted horizontally or vertically, it is essential that it?s located high enough to be above any sludge and debris buildup in the bottom of the tank. Likewise, for both mounting methods, the entire heated length of the heater must be immersed at all times?which is one reason vertical mounting is often not recommended. It is also important to avoid locating heaters in restricted spaces that limit convective flow and where free boiling or steam traps could occur.
9. Prevent build-up and sludge on the heater elements. Scale, coking, and sludge build-up on heater sheaths must be minimized. If not periodically removed or at least minimized, they will inhibit heat transfer to the liquid.
This causes the heater elements to operate at higher temperatures and lead to early heater failure. Extreme caution should also be taken not to get silicone lubricant on the heated section of a heater. Silicone will prevent the ?wetting? of the sheath by the liquid, act as an insulator, and possibly cause the heater to fail.
10. Ensure proper, tight temperature control and safety limit protection. Matching the proper temperature control system to the heaters is imperative to the performance and life of your heaters. Each process application should at a minimum have a process temperature sensor (senses the material heated) and a limit sensor (senses the heater sheath temperature). The process sensor should be either immersed directly into the material to be heated or snugly fit into a well inserted into the fluid itself.
For safety, two separate control systems should be used: one for process temperature control and one for high-limit control.
Proportional/integral/derivative (PID) process temperature control offers stable temperature control and faster response than on/off switching controls or thermostats. The tradeoff is that PID control is more expensive.
