Top-Entry Robot Is Designed For Medium Tonnage MachinesTop-Entry Robot Is Designed For Medium Tonnage Machines
April 1, 2000
Top-Entry Robot Is Designed ForMedium Tonnage Machines
groupimage12.jpgThe TE-7 robot from Husky is a top-entry robot for injection molding machines in the 250 to 550-ton range. Husky says the unit is capable of a 6-sec dry cycle, with an 'in/out' time of 0.5 sec under a payload of 15.4 lb.
The TE-7 has digital ac drives on the three main axes and a locking wrist to maintain end-of-arm tool position while in the mold. The X axis has an 800 mm stroke, the Y axis a 1400 mm stroke and the Z axis a 2500 or 3000 mm stroke.
Other features include two end-of-arm tool vacuum circuits with built-in vacuum sensors and blowoff, four end-of-arm tool air circuits with mating connector, end-of-arm tool electrical interface (three inputs, one output at 24 v dc), and an interface for the perimeter guard and E-stop.
The robot is said to offer the convenience of centralized control when installed on the manufacturer's G-Series injection molding machines by sharing the machine's Human Machine Interface.
For other machine makes, the robot is controlled by a teach pendant. Either way, robot programming is said to be made easy by selecting from a set of pre-defined sequences to suit the application. Pricing is said to be competitive.
Husky Injection MoldingSystems Ltd.
Bolton, Ontario Canada
