Vacuum pump inlet traps allow visual inspection at point-of-use
A line of low-cost, transparent point-of-use vacuum pump inlet traps that can be installed for each tool to prevent users from contaminating central source vacuum systems is available from the MV Products Division of Mass-Vac, Inc. (No. Billerica, MA)
NF_110202_Venmark_lo_res.jpgMV VisiTrap Vacuum Inlet Traps have clear 9.5" sumps for visually monitoring filter condition. Featuring a selection of filter elements, these see-thru traps can protect vacuum pumps from acids, organic solvents, oil back-streaming, particulates and water vapor.
Suitable for vacuum system drops in laboratories with fume hoods and other research and production environments, MV VisiTrap Vacuum Inlet Traps can be supplied with replaceable copper- or stainless steel gauze, molecular sieve, Sodasorb, activated charcoal, activated alumina, and Polypro 2-, 5- and 20 µm filter elements. An optional wall mount bracket is offered. MV Visi Trap Vacuum Inlet Traps are priced from $80.00 to $115.00 depending upon the filter selected.-[email protected]
