Venturi conveying
A full line of transfer tubes for building vacuum conveyor systems powered by compressed air to feed hoppers and remove waste is now available from Anver Corp. (Hudson, MA). Anver TT Series Transfer Tubes employ the Venturi principle to instantly create vacuum, controlled by regulating the input pressure, for conveying a wide range of materials at different speeds. Featuring smooth bores and no moving parts, the transfer tubes are maintenance-free and explosion-proof. The tubes come in bore sizes from 0.375- to 1.0-inch ID, with infinitely adjustable air flow from 15-95 SCFM (standard cubic feet per minute), respectively.  Machined from aluminum and anodized, these transfer tubes use no gaskets or O-rings, and are available with optional mounting clips. One air source can operate several tubes. [email protected]
