Volumetric masterbatch coloring systemVolumetric masterbatch coloring system
July 1, 2004
Microblend, a volumetric dosing system for masterbatches, is designed for use with injection molding machines with clamping forces of up to 100 tons. The unit uses an auger feeder with good accuracy and is said to be easy to handle, cost efficient, compact in design, and low in weight for quick and easy startup. Up to four additives can be refilled manually or automatically, which is ideal for small-capacity screw-feeding and -blending systems. The unit?s control system was designed with a 3-m connection cable for convenient placement. Its hoppers are made of electropolished stainless steel with a stainless steel screw and jacket tubes.
Colortronic North America Inc., Runnemede, NJ
(856) 312-9600
www.colortronic.com
