Water-Proof Sheet Welder Said To Be Fast, Easy To Use
August 1, 2001
August, 2001
Welding:
Water-Proof Sheet WelderSaid To Be Fast, Easy To Use
0801pn-37.jpgLeister's Astro hot-wedge welding machine is designed to quickly and easily weld water-proof sheet used, for example, in foundation engineering. It works with high-density polyethylene in thicknesses from 1.5 to 3 mm, at speeds up to 5 m/sec.
Two functions can be performed at the same time: pressure regulation and wedge advancement. Continuous regulation of the joining pressure setting, as well as joining pressure compensation of the feed rollers by means of a pendulum head, is said to make it easy to weld T-joints.
Leister ProcessTechnologies
Sarnen, Switzerland
