Feedblock, Flat Die And Coating Station Now Available in U.S.
February 1, 2001
Extrusion Tooling:
ER-WE-PA Davis-Standard has three new extrusion tooling products: the Lamella-Feedblock for the production of coextruded multi-layer structure in flat filmcoextrusion, the automatic 310A die for single coating and coextrusion coating applications and a coating station with an engraved roller for rotogravure coating. These items were developed in Germany but are available from Davis-Standard's New Jersey location.
Coextrusion feedblock The Lamella-Feedblock is located in front of the flat film die, and exchangeable feedblock inserts are said to simplify production and reproducibility of multi-layer structures.
Examples of multi-layer structures produced with the feedblock include AB (5%/95%) and BAB (5%/90%/5%), as well as barrier structures with five, seven or more layers, such as CBABC (40%-PP/5%- adhesive/10%-EVOH/5%-adhesive/40%-PP) with or without barrier layer side encapsulation. A scrap layer can also be added on one or both sides.
Automatic flat die, the 310A, features a coathanger manifold with a die control program characterized by short reaction times. It has a slot width range of 800 to 5000 mm. A cross-profile control on the die is available via push-pull expansion bolts, which are temperature controlled.
Other features include a deckling system with edge bead reduction, removable/ exchangeable die lips, chrome-plated flow channel, pre-wired cartridge heaters and insulation on the top and sides of the die.
Coating station is designed for line speeds up to 400 m/min and is equipped with a gravure roll and pressure roll. The station can be used for rotogravure coating and has a doctor blade in two directions.
Maximum web width is 1700 mm; minimum is 800 mm. Unit also has a height adjustable ink pan with reverse movement to the tank.
The pressure roll features pneumatic adjustment, an automatic release at line stop, digital pressure indication and a sleeve changing system. Because the sleeves can be changed laterally, it is not necessary to cut the web.
Somerville, NJ
