Bushing for single-drop direct route
Small, single-drop direct parts and direct runner sprue gating are two areas where the integrally heated 750 hot sprue bushing from D-M-E (Madison Heights, MI) can benefit processors. Heat transfer capability has reportedly been enhanced via an integrally heated design, resulting in a more uniform heat profile. The bushing’s replaceable thermocouple, strategically located near the melt flow channel, optimizes processing conditions for a wide range of  thermoplastics, according to the supplier.
IMM Staff
December 3, 2009
“The ability to eliminate sprues, reduce cycle times, and increase production are important capabilities all molders need in order to maintain a competitive advantage,” says Craig Kovacic, global manager of hot runner systems at D-M-E.
The medium-volume 750 bushing’s streamlined flow channel terminates in a reverse-taper gate, providing minimal pressure loss and allowing for rapid gate freeze. The formation of a small gate stub on the part or runner results in a machine hold-time reduction, with no increase in sink marks on the part.
With a 0.187-inch flow diameter, the 750 bushing is offered in two head styles and two gate styles to suit a broad range of applications. Other radius head options are available upon request. —[email protected]
