By Design: Designing with polycarbonate
If you need a transparent engineering plastic with high heat and impact resistance, polycarbonate is a good choice.If you handle a compact disk today you will be touching polycarbonate (PC). To date PC is the only material capable of filling the demanding requirements of that application.
January 1, 2005
In 1859 the Russian chemist Butlerov described a PC type of material. This discovery was repeated by Einhorn in the late 1800s. Fifty years passed before these discoveries were seriously pursued by General Electric in the U.S. and Farbenfabriken Bayer in Germany. Both announced pilot plant quantities in 1956. One hundred years after Butlerov’s discovery, Bayer was producing commercial quantities under the trade name Makrolon. GE followed with Lexan in 1960 and Dow introduced Calibre in 1984.
There was a waiting market for this unique plastic material. Worldwide consumption reached 40 million lb/year in 1970, and 218 million lb in 1980. This rapid growth is testimonial to the material’s usefulness. Today PC is second only to nylon in volume and is now the fastest-growing engineering polymer.
Designing Characteristics
Polycarbonate is an amorphous thermoplastic that combines transparency with high temperature and impact resistance. There is no other engineering plastic with this combination of properties. There are different types of PC, but a high-viscosity grade can be defined as follows.
Physical properties are around a tensile strength of 9000 psi; flexural modulus is 340,000 psi, with a heat deflection temperature of 270°F at a 264-psi loading. Strength and temperature resistance can be increased with the use of fillers and reinforcements.
Most polycarbonates have a notched Izod impact strength in the range of 12 to 17 ft-lb/in, which is retained at low temperatures. Polycarbonates are highly notch-sensitive materials. They actually have higher impact strength than indicated by the standard notched Izod impact test. For example, a .125-inch-thick, right-angled-shaped part with an inside corner radius of .010 inch had an impact strength of 2.5 ft-lb. Increasing that radius to .020 inch resulted in an impact strength of 20.2 ft-lb. In other words, doubling the size of the radius increased the impact strength by a factor of eight. This is the reason why designers make such a fetish of radiusing the corners on PC parts.
Light transmission is 86% to 89%. This is just below acrylic at 91% to 92% and general purpose polystyrene at 88% to 91%.
Flame-retardant grades are available with a UL 94 V-0 and 5V ratings.
Polycarbonate has an excellent balance of physical properties, but it lacks the chemical resistance of semicrystalline polymers. Specifying PC requires careful attention to the chemical environment of the application.
Polycarbonate is also available alloyed with ABS, acrylic, polyetherimide, polyurethane, PBT, and PET polyesters. The base polymer and all of these alloys can be tailored for specific applications with the addition of fillers and/or fiber reinforcement.
Polycarbonate fills the gap between ABS and PPO and the higher-temperature-resistant and more costly materials such as polysulfone, polyetherimide, polyphenylene sulfide, and liquid crystal polymers. The list price for injection molding grades of PC was $1.96/lb in 1988. Today the material costs $1.38 to $1.65/lb, or an average of $.065/cu in. These prices are, however, increasing.
Applications
GE is a major user of electrical insulating materials. The good electrical properties of PC are one of the reasons why GE originally pursued the development of this material. A favorable UL rating, plus low smoke and corrosive gas emissions, accounts for PC’s use in telephones, computers, printers, copiers, other business machines, and laboratory and diagnostic equipment.
The combination of transparency, coupled with weatherability and impact strength, allows PC to be used for bulletproof windows, machine guards, lighting applications, and as window panes, especially in those instances where vandalism is a problem. Other transparent applications include greenhouse glazing, optical safety lenses, solar collectors, and automobile head and taillight lenses. A large new application just now being commercialized is side and rear car windows.
This FDA-sanctioned material has a long history in the food handling industry as processing bowls, mugs and glasses, tableware, pitchers, storage containers, baby and water cooler bottles, and in some instances as microwave cookware. Many of these applications rely on PC’s transparency and temperature resistance.
The amount of PC used in the construction industry is second only to PVC. Other markets include medical products, toys, portable tools, and photographic and sporting equipment, especially in applications where low-temperature impact strength is important.
