Redesign: Out with sheet metal, in with plastics, and way, way up with the savings
Don't just demand lower prices from your suppliers, learn where their costs are created and then help them reduce those. That's the moral of this story, in which a mechanical engineer at a veterinary device manufacturer used DFMA software and worked with his injection molding supplier, PTA Corp., to turn 43 parts into a single injection molding, consolidated 30 other parts into just four plastics ones, all courtesy of a mammoth metal-to-plastic conversion.
November 19, 2010
Justin Griffin, an R&D mechanical engineer at IDEXX Laboratories of Westbrook, ME, began his design for manufacturing and assembly (DFMA) journey when he was tasked to redesign his company's Catalyst Dx blood chemistry analyzer for the veterinary market. Each product redesign offers engineers a fresh opportunity to break with convention. But with deadlines looming, they can often feel pushed to re-purpose an existing Bill-of-Materials (BOM) and just tweak critical features.
Griffin took the road less traveled. Tearing apart the analyzer, he found a subassembly with a main sheet-metal panel, 183 parts, and 63 fasteners-each with its own torque-spec and an assembly process that required a worker to both tighten and mark it. "This very traditional and now outdated system was just ripe for improvement," says Griffin.
Using DFMA to cut costs, save time and improve your product on PhotoPeach
The instrument being scrutinized by Griffin was the company's flagship product. The redesign goals included upgraded functionality as well as a 20% cost cut, decreased weight and assembly time, and improvements in service and warranty.
To hit these targets, Griffin identified the Maintenance Access Door (MAD) as the top redesign candidate (this subassembly provides customers with access for both loading slide samples and self-service) (see Figure 1). "We chose the MAD because it had a lot of low-hanging fruit for increasing reliability and lowering the cost," says Griffin. "I suspected that plastic parts were going to play a huge role in our new approach," he adds. "But I needed to back that up with some hard facts."
DFMA "should-cost" approach guides the redesign
To provide data about design changes and material choices, Griffin employed Design for Manufacture and Assembly (DFMA) software from Boothroyd Dewhurst (Wakefield, RI). He had never used the tool, but a recently hired VP of R&D at IDEXX, familiar with the software, insisted on its adoption throughout the entire engineering organization.
"When we began, we brought an engineer in from Boothroyd Dewhurst and meticulously went through the old MAD assembly," says Griffin. "The software asked a lot of questions about the design. It asked us to analyze every piece. In the end, we came up with three alternates and decided to go for the most ambitious change."
To facilitate product development, DFMA provides a two-pronged approach. The Design for Assembly (DFA) module leads an engineer down a quantifiable path of parts consolidation and assembly simplification. "The software methodically guides you towards designs that have fewer parts and lower costs," says Griffin. "It forces you to answer questions that you might not have otherwise asked, like, 'Does this part move relative to this neighboring part?' or, 'Why don't you use a snap feature instead of a screw?'"
The Design for Manufacture (DFM) module complements DFA by examining manufacturing processes and material choices, again using a series of queries and reports. "It asks you about every detail," says Griffin, "generating questions such as, 'Could this part be manufactured from a different material?' or, "Should this part be stamped, molded, or machined?'"
As a result of this methodology, cost estimates and comparisons are available early in product development. "DFMA does an excellent job of providing a structured and measurable approach to scoring designs," says Griffin. "It forces you to think differently about your product."
DFMA also pushes a user to repeatedly reexamine his design during the analysis process. "The software gave me information such as which parts could be consolidated or which ones were candidates for elimination," Griffin says. "So I would go back to the design and revise it." After six or seven iterations and incremental improvements at each stage, Griffin settled on a new subassembly.
Two-pronged approach leads to one answer: injection molding
As Griffin had predicted, the DFMA redesign identified injection molding as the best substitute for sheet metal and assorted fasteners. "Plastics give you the flexibility to mold in a lot of features at relatively low cost," says Griffin. "Snap and slip fits, for example, eliminate fasteners and reduce the weight of the assembly. Plastics can also provide excellent durability and can even eliminate lubrication in moving parts if the correct material is chosen."
Griffin chose one of compounder LNP's Lubriloy self-lubricating compounds as the basis for the subassembly's operational system. This material was picked because certain parts needed to be dimensionally stable while able to withstand years of use with sliding doors and moveable fits that contacted the remaining sheet metal parts.
Next, he selected polycarbonate (PC) for its hard, opaque attributes and used it as a light block for a photosensitive detector; its resistance to chipping or deformation was important, since nicks or edges could generate false optical signals. A third plastic, acrylonitrile butadiene styrene (ABS) was used for structural parts because of its stability and low cost.
Working with these materials, Griffin was able to take the 43-part main panel of the subassembly and redesign it as a single injection molded piece that included snap fits for the circuit board, a snap-fitted motor mount, and a molded-in rack for a damper gear (see Figure 2). For another component (two identical moving doors), he was able to consolidate 30 parts into four, also by switching to plastic (see Figure 3).
Benchmarking the redesign and comparing it with the original design, the results were dramatic: parts were reduced 83%; time to assemble was cut 75%; weight was lowered 40%; and the cost of assembly was reduced 38%. From a service and warranty standpoint, out-of-box failures caused by hardware not having proper torque (which were rare to begin with) were completely eliminated now that all the hardware was removed (see Figures 4 and 5). "We designed out all of the fasteners that you had to put a wrench or screwdriver on," says Griffin. "Some of the non-technical members of the team couldn't understand how the unit could stay together without screws and nuts."
Talking to suppliers, such as plastics processors, just got easier
Important in the manufacture of the new MAD subassembly were relationships with two suppliers: CBM Industries, a contract assembler in Taunton, Massachusetts, and PTA Corp., an injection molder in Oxford, Connecticut. And while DFMA had given Griffin a window into cost-saving design features, it also gave the IDEXX team an inside view of the suppliers' challenges and costs.
Designers of molded parts, according to Griffin, often look at designs and do calculations in their heads based on experience about shot size, cooling times, energy expenditure, moldmaking, tooling, and other factors. "They do it intuitively," he adds. "Very few quantify their thinking."
But DFMA quantified all of those factors. So when the purchasing team approached the molder, they were prepared with specific information about materials, processes, and tooling. "DFMA told us things like how big the shot size is, how much time it's going to take to cool, and how much it's going to cost to build a mold," says Griffin. "Our numbers were pretty close to theirs, so the molder knew that we understood." With the assembler the story was the same. And rather than being protective of their intellectual property, the two suppliers were receptive to be having these sorts of conversations.
With both the molder and the assembler, DFMA served as a catalyst for collaboration. The result was targeted discussions about materials, processes, setup, labor, and volume. By focusing supplier conversations on topics other than margins and profits, negotiations became much more productive.
"Demanding lower prices from suppliers just isn't as effective as demonstrating that you understand their costs," Griffin says. "Purchasing now has the ability to ask pointed questions of suppliers and knows where the costs are coming from. DFMA has fundamentally changed the way we communicate with our outside partners."
Adding up all the DFMA positives
Beyond the instant gratification of achieving all of the specific redesign goals for the Catalyst Dx-parts consolidation, assembly simplification, cost reduction, and warranty and service improvement-other benefits for the OEM also have been realized. For one, it says its relations with its suppliers now are focused on win-win. Also, MRP/ERP for the Catalyst has been streamlined because there are now significantly fewer parts to track and control.
Looking forward, the most significant benefit might be a shift in the engineering culture of the company. "DFMA drives us to go back to the drawing board to find opportunities to improve our designs," says Griffin. "We've adopted it into our process flow. A DFMA review is now required for every design project."
