Sterling loading performance
Sterling (New Berlin, WI) has introduced the SVL series of self-contained air loaders. These units provide efficient conveying of resins from drums, bins, material bags, and gaylords with the use of an efficient compressed-air venturi system. A standard flange with quick-release fasteners allows for fast and easy material changes and cleanout, while a simple control assembly ensures easy-to-use operation.
IMM Staff
September 29, 2009
Available models include the single-inlet SVL-A used to convey clean, pelletized material into a process. Additional features include a control assembly with a low-power-consumption solenoid, air filter/regulator combination with pressure gauge, and a capacitive sensor for material demand. The single-inlet SVL-B can be used for both pellets and regrind and otherwise includes the same features as the SVL-A. Further, the SVL-C is a single-inlet venturi for both pellets and regrind with a special attachment that allows for conveying of two materials (usually a virgin and a regrind) into a process. The SVL-C has similar features to the SVL-B in addition to a second control assembly for the second venturi (including air regulator with pressure gauges). Finally, the SVL-D is a mobile stand with a single inlet that is used to unload bins or grinders and to load barrels. A premium energy-saving control with alarm features is available as an option for all models. —[email protected]
