Ascend to launch new polyamides at K 2019
Among the new products is Vydyne XHT, designed to perform across a "broad operating window for customers, who are today limited to products with narrow operating windows and poor performance outside those windows,” said Ascend (Houston, TX).
September 18, 2019
Ascend Performance Materials (Houston, TX) today announced plans to launch several new specialty polyamides at K 2019 to meet the growing needs of its customers. Among the new products are Vydyne XHT, long-chain polyamides and high-temperature polyamides.
Vydyne XHT, a new portfolio of heat-stabilized polyamide (PA) 66 and copolymers, is capable of withstanding prolonged exposure to temperatures up to 230°C. |
Vydyne XHT, a new portfolio of heat-stabilized polyamide (PA) 66 and copolymers, is capable of withstanding prolonged exposure to temperatures up to 230°C. Using a combination of unique polymer chemistries and a multi-stage heat stabilization technology, XHT products push the boundaries of temperature resistance without sacrificing the processability, durability and mechanical properties PA 66 is known for.
“Consistent high heat performance is critical in under-the-hood applications to accommodate for various load, torque and speed conditions in engines,” said Vikram Gopal, Ascend’s senior vice president of technology. “We created Vydyne XHT to perform across a broad operating window for our customers, who are today limited to products with narrow operating windows and poor performance outside those windows.”
The Vydyne XHT portfolio includes four glass-filled grades ideal for use in demanding automotive applications, such as charge air coolers, integrated air intake manifolds, exhaust gas recirculators and resonators. All XHT grades exhibit excellent flow and are regrindable, allowing excess material to be reprocessed, thus improving production efficiency.
Ascend will also introduce a new portfolio of PA 610 and PA 612 long-chain polyamides. With low moisture absorption, high chemical and UV resistance, Ascend’s LCPA are engineered for a variety of applications, including monofilaments, battery seals, cable ties, automotive cooling and fuel connectors, and sporting goods.
“Our customers are driving innovation and meeting increasing demands across the industries they serve,” said Phil McDivitt, Ascend’s president and CEO. “In turn, we are building off our vertical integration and strong position in PA66 to bring the greater reliability, functionality and flexibility to make that innovation possible.”
The company is also expanding into high-temperature polyamides. Ascend’s new HTPA grades offer higher strength, stiffness, chemical- and temperature-resistance for metal replacement and high-heat automotive applications.
