All-terrain vehicle's overmolded gear employs PAEK grade
BPG Werks (Boston, MA and Toronto, ON), creators of the innovative all-terrain dual tracked vehicle (DTV) called the Shredder, have harnessed the exceptional durability and wear capabilities of a high-performance polyaryletherketone resin from Victrex (Thornton Cleveleys, UK) to construct a robust and efficient overmolded steel drive shaft segment gear.
May 30, 2014
Replacing a coated brass gear, which did not offer the required lifetime, the thermoplastic reportedly delivers a more durable, more reliable transmission solution, with remarkably smooth torque and acceleration response and offers lower vibration levels that add to the driving experience.
The Shredder, a powerful all-terrain vehicle, relies on a steel drive shaft overmolded with Victrex WG. |
Working in conjunction with China Array Plastics (Pittsfield, MA and Wuhan, China), BPG Werks chose to specify Victrex polyetheretherketone WG polymer in the continuously variable transmission (CVT) of their Shredder dual tracked vehicle. This wear grade, developed by Victrex, the world leader in high performance polyaryletherketone solutions, contributes to the durability and performance of the transmission.
The Shredder is a powerful all-terrain vehicle for extreme sports or agricultural or forestry work. Its patented continuously variable transmission provides quick, reliable acceleration and outstanding torque response. Users can often go from a complete stop to top speed even on steep, uneven terrain or through water, dust and rocky environments. To transfer power from the 13-horsepower, four-stroke engine to the heavy duty rubber tank tracks, the polymer overmolded steel drive segment gear needs to provide solid performance with low vibration and a long lifetime at high rpm.
China Array utilises Victrex WG polymer for two components of the CVT, sliders and insert keys. Despite exposure to centrifugal and linear forces at high temperatures, the extremely robust thermoplastic offers a lightweight, durable solution.
"We looked at a couple of other materials, including MoS2-coated bronze. It did not demonstrate the same durability as the wear resistant material from Victrex. With exceptional friction and heat resistance, the Victrex WG polymer overmold, although being in constant contact with the belt drive, helps to provide stable acceleration and torque characteristics. This is due to the polymer's durability, impact and tensile strength, and low friction coefficient," explained Russell Johnson, President of China Array Plastics, Massachusetts.
Lighter in weight and resistant to corrosion, compared to steel, Victrex WG 101 provides a cushioning effect for low vibration operation. The eight slider mechanisms, produced from Victrex WG polymer overmolded sliders and insert keys, are a critical element of the transmission system. Sliding back and forth thousands of times within the transmission, while under load, the thermoplastic offers high wear resistance while maintaining dimensional integrity, resulting in solid synchronisation and an exceptional driving and riding experience.
